The DSM Explorer › Control Panel › Configuration Folder › Configuration Policy › Default Computer Policy (or User-Defined Policy) Node › Agent Policy Group › Common Agent Policy Group › Common Policy Group (Common Agent) › How to Enable and Configure Location Awareness
(Optional) Configure Script Timeout
The Script Timeout configuration determines the maximum interval during which to run the script. The scripts stop running when the specified interval elapses.
- Select Script Timeout, then click Setting Properties in the Tasks portlet.
The Setting Properties dialog opens.
- Modify the Value field as appropriate for your environment, then click OK.
Values:
- 0: Infinite Timeout
- >0: Number of seconds to run the script before timeout
- Maximum allowed timeout value: 600 seconds (10 Minutes)
Default: 300
The Script Timeout parameter settings are configured.
