The DSM Explorer › Control Panel › Configuration Folder › Configuration Policy › Default Computer Policy (or User-Defined Policy) Node › Agent Policy Group › Common Agent Policy Group › Common Policy Group (Common Agent) › How to Enable and Configure Location Awareness
(Optional) Configure Scan Timeout
If you use the Subnet Scan, the Scan Timeout configuration determines the maximum interval that the scan waits for a scalability server to respond.
- Double-click Configure Scan Timeout, then click Setting Properties in the Tasks portlet.
The Setting Properties dialog opens.
- Modify the Value field as appropriate for your environment, then click OK.
Default: 30
The Configure Scan Timeout parameter is configured.
