Wake a Virtual Machine Using the CLI
You can wake a virtual machine using the CLI. For example, when you want to wake multiple virtual machines using a batch script. The following command wakes a virtual machine:
caf sendwol [user username password password] vm vGUID guid vsvr url rviagent fqdn
Specifies the credentials of an administrative user on the AM remote agent computer. When you use the same computer credential that you are executing the CLI, you can skip the parameters.
Specifies that virtual WOL must be performed.
Specifies the ID of the virtual machine as known to the host. The ID can be a virtual GUID, system ID, or serial number depending on the platform virtualization server type.
Specifies the URL of the virtual server host of the current virtual machine.
Specifies the FQDN of the AM remote agent that discovered the virtual machine.
Virtual WOL Example
This example performs virtual WOL on a virtual machine:
caf sendwol user root password secret vm vsvr https://virt.acme.com/sdk vguid 123456 rviagent rvi3.acme.com
Note: For more detailed information about CAF commands, type caf <command> /? at the command prompt.
