The DSM Explorer › Control Panel › How to Configure and Authenticate External Directories › Supported External Directories › Specify the Base Directory Node Details
Use the Base Directory Node wizard page to specify the root node from which directory browsing starts.
- In the Base Directory Node field, enter the Distinguished Name (DN) of the root object for browsing the current directory.
Note: Try to use the lowest possible Base DN in the directory hierarchy as possible to ensure that searches are more efficient. Your directory administrator can tell you the best value to use.
- Click Next to go to the Choose Schema Mapping page.
