The DSM Explorer › Control Panel › How to Configure and Authenticate External Directories › Supported External Directories
Client Automation supports the following directories:
- Lightweight Directory Access Protocol (LDAP)
- Microsoft Active Directory
See Compatibility Matrix for an updated list of the supported directory integration services.
Verify the Prerequisites
To authenticate using an external directory, verify the following prerequisites:
- Verify you have access permissions to configure an external directory.
- Ensure you have working knowledge of Directory Integration capability.
Add a Directory to the Repository
To authenticate users and authorize users by mapping security profiles to entities in the directory, add the external directory to the repository first.
- Navigate to the Control Panel, Directory Integration, Add Directory to access the Add Directory Wizard, Click Next.
The Introduction/Directory Name page appears.
- Specify the directory name to identify the directory when connecting to Active Directory in Directory Name.
- Select the type of directory using one of the Directory Type options. The following options are available:
Default: Active Directory.
- Click Next to go to the Server Details page.
