A linked object can be an asset group for the asset jobs and collect tasks; can be an engine for the engine tasks. This object indicates the engines or asset groups associated with the selected job or task. On the right pane, you can see the status and the number of runs of the job or task. If the job or task is enabled in the asset group or engine, the status shows OK; otherwise, it shows Disabled. You can right-click this object in the tree view to do one of the following:
Disables or enables the job or task in the asset group or engine. If you select disable, the status of the task in the right pane changes to Disabled.
Unlinks the job or task from the asset group or engine and removes the reference to the object from this location.
Opens the Action Status dialog displaying the status of the selected job or task, date and time of last run and the number of runs.
