If you want to perform the same collect task on various assets, you can create the collect task once and link it to all other assets. You can link the collect task created at the domain level, group level, and asset level.
Note: A collect task created at the domain level can be dragged and dropped on to the target assets.
To link an existing collect task to an asset
All the collect tasks linked to the computer appear.
The Select Collect Tasks dialog appears.
The selected collect tasks are linked to the asset.
Note: A virtual host inventory collect task can be created only for an asset or agent that has the AM remote agent (AMRemoteAgent) installed, and it can be linked only to other agents of the same OS class. For example, a virtual host inventory collect task created for a Windows agent can be linked only to other Windows agents.
