The Software folder lists all software-related items associated with the current group, and its corresponding Software pane provides the following option in the Tasks portlet:
Opens the File Search dialog.
The Software folder contains the following subfolders:
Shows all software that has been detected on all computers in the group.
Shows files that have been configured to be collected for members of the group. The Tasks portlet in the corresponding File Collection pane has the following option:
Opens the Select Files to Collect dialog.
Shows a list of software policies. The Tasks portlet in the corresponding Software Policies pane has the following option:
Launches the Create Software Policy Wizard.
Shows executables that are not matched against any of the software definitions. Additionally, if the signature scanner is configured to detect unknown virtual application images, unknown virtual application images are also displayed.
Shows tracked software usage.
Note: Available categories and options may vary depending on the products and components installed.
