Previous Topic: Register an Unknown Virtual Application ImageNext Topic: Offline Utilization View Window
Usage
The Usage pane displays the offline software usage information in an asset or group. You can view the start time and stop time of all the monitored applications in this pane.
This pane contains the following offline usage information:
Application
Shows the names of the applications being monitored for usage.
Action
Shows the actions to be taken on the assets when the maximum number of used licenses is reached.
Start Time
Displays the date and time when the application was opened on the asset.
Stop Time
Displays the date and time when the application was closed on the asset.
Computer
Displays the name of the computer that has used the application.
Note: This information is available only at the group level.
Right-click Usage in the tree view and select View from the context menu to open the Online / Offline Utilization window where you can view the usage information.
More information:
Software Usage Collect Task
