You can register unknown virtual application images as valid software definitions, so that the next time you run the scan, this software is automatically detected and removed from the Unknown list.
To register an unknown virtual application image
A list of unknown software files and virtual application images detected on the selected computer is displayed.
The Create New Virtual Application Image Definition dialog appears with preset values in the General and Recognition tabs.
The new, unsealed software definition is added to the Virtual Application Images list under the Definitions node.
The unknown virtual application image is registered as a valid software definition.
