Previous Topic: UsageNext Topic: Online Utilization View Window
Offline Utilization View Window
The Offline Utilization window lets you view usage information in different ways.
The Data menu in this window contains the following options:
Offline utilization view
Opens the Offline Utilization window that displays the offline utilization information of the selected software.
Online utilization view
Opens the Online Utilization window that displays the online utilization information of the selected software.
Online Queuing
Opens the Queue application name window that displays the currently queued assets that have been prevented from launching the application.
Current Queue
Opens the Release of Application dialog that displays the assets in queue.
Auditing
Displays all activities concerning the .dll and/or .exe files to be monitored are displayed.
Import to DB
Imports the current utilization data into the domain database.
The View menu contains the following menu options:
Graph view
Plots the usage information (for a defined period) on a graph.
Statistics view
Provides detailed statistic information on the assets using the selected application in the specified time span.
Detail view
Provides time-related information about the selected asset in list form.
The Filter menu contains the following menu options:
Action
Activates the actions that appear in the list that follows.
Execution prevented
Shows those applications that have been prevented from execution.
Started normally, Stopped normally
Shows those applications that have been started and stopped normally.
Started with warning, Stopped normally
Shows those applications that have been started with a warning and stopped normally.
Started normally, Software Usage agent stopped
Shows those applications that have been started normally and stopped by the Software Usage agent.
Started with warning, Software Usage agent stopped
Shows those applications that have been started with a warning and stopped by the Software Usage agent.
Time Span
Specifies the start time for view in the Start Time field and stop time for view in the Stop Time field.
Defaults: Start Time = today minus two whole days; Stop Time =today
