The Module Status table, STATMOD, stores the collect task status information.
This table contains the following columns:
Includes the automatic increment counter used by the replication engine for comparing the values before and after the update.
Includes the module domain ID.
Includes the module ID.
Includes the object domain UUID used for replication.
Includes the type of object.
Example: ca_discovered_hardware=1, ca_discovered_user=2.
Object UUID. Foreign key to either ca_discovered_hardware or ca_discovered_user depending on object_type.
Includes the collect task status.
Includes the number of times the collect task has been executed.
Includes the date of last status update.
Includes the elapsed time for the last execution of the collect task (in seconds).
Indicates whether status text is required.
Example: 0=None, 1=More
Includes the number of times the collect task has been cancelled.
Includes the revisions number
Includes the status text. This column can contain up to 127 characters.
