The Agent tab contains agent-related information for external agents when the Asset Collector component is installed.
This tab contains the following fields:
Identifies the agent name.
Identifies the date and time when the agent was registered.
Identifies the date and time when the agent was last run.
Identifies the last IP address of the agent. If the agent is configured through DHCP (Dynamic Host Configuration Protocol), each time the DHCP Server is restarted, a new IP address is assigned to all the systems connected to the server. This field displays the last IP address of the agent.
Identifies the host name of the scalability server that this agent reports to.
Shows the agent restrictions, if any. Valid restrictions are as follows:
Identifies the trust level of an asset. Trust level is displayed as a range of 1 to 5 stars, 5 being the most trustworthy
Identifies the source from which the asset is collected.
Provides a brief computer description.
