The Agent tab contains agent-related information for DSM agents.
This tab contains the following fields:
Identifies the agent name.
Identifies the date and time when the agent was registered.
Identifies the date and time when the agent was last run.
Identifies the last IP address of the agent. If the agent is configured through DHCP (Dynamic Host Configuration Protocol), each time the DHCP Server is restarted, a new IP address is assigned to all the systems connected to the server. This field displays the last IP address of the agent.
Identifies the host name of the scalability server that this agent reports to.
Shows the agent restrictions, if any. Valid restrictions are as follows:
Indicates the trust level that is sent to the server by the asset. Valid values are 1–5, with 1 being the least trustworthy and 5 the most trustworthy.
Indicates the source, or origin, of the asset.
Identifies the various agent plug-ins deployed and running on the computer.
Identifies the version numbers of the various agent plug-ins.
Provides a brief computer description.
