The information pane, visible on the right-hand side of the DSM Explorer, consists of several portlets. These portlets display additional information like useful links, tips to work with the objects selected, and other tasks that can be accomplished in this pane. You can use the Customize Information Pane dialog to customize the layout of the portlets on this pane.
This dialog has the following buttons that enable you to customize the appearance of portlets in the information pane.
Moves the selected portlet up in the order of appearance in the information pane.
Moves the selected portlet down in the order of appearance in the information pane.
Enables the portlet and shows it in the information pane.
Disables the portlet and hides it in the information pane.
Select the check box of a portlet to show it in the information pane. You can use this as an alternative to the Show/Hide buttons.
Note: Press the Ctrl key to select more than one portlet at a time.
