The deployment manager scans or runs a detection mechanism on the target computer. The detection mechanism identifies the following:
The scan can return one of the following values:
The same version of the package is installed on the target
Deployment of this package to the target has already started
The address specified is valid and the machine is running.
The target address has a valid name that can be resolved by network name to address translation. Check that the target computer is switched on.
A newer version of the package is present on the target machine. Deployment will not be performed unless the Always deploy packages policy is set to True.
An older version of the package is already installed on the target computer. Deployment will be performed.
A version of the package is already staged on the target scalability server. The package will be re-staged if the user continues with the staging job.
The presence of the package on a target cannot be determined. Ensure that the device exists.
