The Others category contains the objects that are not placed in any of the folders in DSM Explorer.
Includes access permissions for the Security Profiles dialog and lets you add, re-map and delete security profiles.
Includes access permissions for the Security Areas dialog and lets you manage security areas.
Includes access permissions for the Class Permissions dialog and lets you modify the class access.
Note: To change class permissions, you need the Change Permissions (P) right.
Includes access permissions for the Report Templates available in the DSM Reporter application.
Includes access permissions for the Scheduled Reports available in the DSM Reporter application.
Includes access permissions to retrieve or change the password of the DB user ca_itrm.
