If you want to grant access rights to a particular folder, you need to know its object class.
To identify the class of an object
The Object Permissions dialog or Security Groups Permissions dialog appears.
You can specify the class permissions for this object class in the Class Permissions dialog.
Note: Class permissions are applicable to all objects in the class.
