Previous Topic: Create a Service Desk TicketNext Topic: Run the Asset Job Check
Link Existing Job
Use this procedure to add a job to a group of assets, that is, computers or user accounts.
To link a job to an asset group
In the Select Asset Jobs dialog, select the job you want to link and click OK.
Note: Press the Shift key to select multiple jobs at once.
The job is added to your asset group.
Note: Available categories and options may vary depending on the products and components installed.
More information:
Jobs Folder
Asset Context Menu Options
