You can modify an existing security profile to remap it to another security principal. In this case, the existing permissions at the class, object and group level remain the same. Remapping a profile is helpful when you want a user to take over the permissions of another user.
To modify a security profile
The Re-map Security Profile dialog appears.
Note: You must have the access rights to open this dialog; otherwise, a security error message is displayed. Administrators (on Windows) and root (on UNIX) have these access rights by default.
The modified profiles are saved to the database.
