Previous Topic: Asset Jobs PaneNext Topic: Edit an Existing Job
Create a New Asset Job
You can create asset jobs to execute certain actions on the assets.
To create a new asset job
  1. Navigate to the appropriate Jobs folder depending on the level where you want to create the job.
    The existing jobs are displayed.
    Note: The Jobs folder is available in three places in the root of the left pane, under each asset, and under each group.
  2. Click New in the Tasks section or right-click the folder and select New.
    The New Job wizard appears.
  3. Follow the instructions in the wizard.
    A job is created and displayed under the selected job category folder and under the Domain, Jobs folder.
