Command jobs are used to execute a DOS or Windows command file or a UNIX shell script on an agent computer. The commands to use are identical to those you usually use for writing commands or script files. By default, asset management provides various predefined command jobs that perform basic and crucial tasks such as, virus scanning, checking the disk, and so on.
This folder lists all command jobs defined in this domain.
Note: You can drag a job to an asset or group on which you want to execute the job.
