Previous Topic: Message JobsNext Topic: Command Jobs
Properties for Job: Message Tab
You can specify the message to be displayed by using the following fields:
Note: Messages appear only on the Windows agent computers.
Message Field
Defines the message that should appear on the asset.
Button Caption
Defines the button caption to be displayed on the message box. By default, the message visible to the user has an OK button. You can customize this to match your message.
Note: The ampersand (&) should be placed in front of the character you want as the shortcut. The character is underscored (_) and the user can press the Alt key + character key.
