The Discovered Software database view, ca_v_discovered_software, displays the same data that is available in the Discovered Software database table plus the following columns specific to virtualized applications:
Indicates the name of the discovered software.
Indicates the format of the discovered software. Valid values are as follows:
0 = Regular application
1 = Virtual application image
2 = Virtualized application.
Indicates the specific software subtype. Valid values are as follows:
0 = Undefined
1 = Patch
2 = Release
3 = Suite
4 = Configuration Settings
5 = Service
6 = Product
7 = Operating System
8 = Virtual Machine
9 = Patch Roll Up
10 = User Defined Patch
11 = SD Installable Patch
12 = Product Family
13 = Undefined
14 = Undefined
Displays the properties of the discovered virtual application image as reported by the agent.
Identifies the name of the virtual application image that contains the discovered virtual application, where Software_format= 1. Anything other than 1, the value will be NULL.
Includes the software definition UUID for the virtual application image, where INSTALLATION_TYPE = 1. Where INSTALLATION_TYPE = 0, this will be NULL.
