You can register unknown software files as valid software definitions, so that the next time you run the scan, this software is automatically detected and removed from the Unknown list.
To register an unknown software file
A list of unknown software files and virtual application images detected on the selected computer is displayed.
The Create New Release dialog appears with preset values in the General and Recognition tabs.
The Organize Product dialog appears.
The search result is displayed.
Note: To select multiple items all at once, press the Shift key (continuous selection) or Ctrl key (random selection) and click the items.
The selected products or suites are added to the Selected Definitions list.
The unknown software file is registered as a valid software definition and is added to all the products or suites in the Selected Definitions list.
