You can configure the common configuration policies to control the intervals at which you want to perform the cache cleanup for the concurrent processes. The intervals specify the time in minutes after which you plan to perform the cache cleanup for the concurrent processes. You can specify different values for different processes.
To configure the cache cleanup interval for the concurrent processes
A list of configuration policies appears.
Controls the frequency at which you want to perform the cache cleanup for the Installation Manager.
Default: 5
Limits: 0 to 10080
Controls the frequency at which you want to perform the cache cleanup for the Notification Manager.
Default: 60
Limits: 0 to 10080
Controls the frequency at which you want to perform the cache cleanup for the Policy Manager.
Default: 60
Limits: 0 to 10080
Controls the frequency at which you want to perform the cache cleanup for the Replication Manager.
Default: 60
Limits: 0 to 10080
Controls the frequency at which you want to perform the cache cleanup for the Task Manager.
Default: 30
Limits: 0 to 10080
The cache cleanup interval is configured for the concurrent processes.
