Previous Topic: Non-Concurrent ModeNext Topic: Configure the Cache Cleanup Interval for the Concurrent Processes
Configure the Task Manager and the Installation Manager Concurrency
Configure the common configuration policies for the Task Manager and the Installation Manager to enable the concurrent mode for these two manager components.
Note: These policies are applicable only for the domain manager.
To configure the Task Manager and the Installation Manager concurrency
  1. Navigate to Control Panel, Configuration, Configuration Policy, policy name, DSM, Software Delivery, Manager.
    A list of configuration policies appears.
  2. Double-click the following policies, and enter appropriate values in the Setting Properties dialog:
    Manager Concurrency: Task Manager Concurrency enabled
    Controls the Task Manager concurrency behavior. You can set the parameter value to True or False. When set to False, the Task Manager runs as a single process and performs the tasks in a sequential manner. When set to True, the Task Manager creates additional manager processes, Policy Manager and Replication Manager, to perform the policy evaluation tasks and the replication tasks. For optimizing manager concurrency, set the value to True.
    Default: True
    Manager Concurrency: Installation Manager Concurrency enabled
    Controls the Installation Manager concurrency behavior. You can set the parameter value to True or False. When set to False, the Installation Manager runs as a single process and performs the notification processing and the database updates alternately. When set to True, the Installation Manager creates an additional manager process, Notification Manager, to handle notifications and messages related to the notifications. For optimizing manager concurrency, set the value to True.
    Default: True
  3. Click OK.
    The concurrency behavior for the Task Manager and the Installation Manager is enabled.
More information:
Concurrent Mode and Non-Concurrent Mode
Concurrent Mode
Non-Concurrent Mode
