To confirm whether the Task Manager is running in concurrent mode or non-concurrent mode, you need to run the caf status command on the domain manager to check the status.
If the caf status command displays the Task Manager (sdmgr_tm), Policy Manager(sdmgr_pm) and Replication Manager (sdmgr_rm) plug-ins in the running state, it implies that the Task Manager is running in concurrent mode.
You can also view the concurrency status of the Task Manager in the DSM Explorer by looking at the status of the System Delivery Engine.
