To edit properties of files contained in the CMP File means to set or modify options, attributes, or the directory path of the files. You can edit properties of multiple files at the same time.
To edit properties of files in the CMP File
The Properties dialog appears, providing the Directory, Attributes, and Options tabs.
Note: If you double-click within one of the File, Attributes, or Options fields of a single file (selected or not), the Properties dialog appears with the relevant Properties tab in front.
The properties changes appear in the CMP File window and the changed files are marked with the File in modification symbol
in the left margin of the CMP File window.
