dsmPush--Push Client Automation Component Installation Packages to Domain Manager › dsmPush copy script—Import Packages into a Library › Using Combinations of Parameters
Important notes on using combinations of the parameters:
- If the operating_environment parameter is not specified, the specified packages are imported for all supported operating environments, independent of the -single option.
- If the product parameter is not specified and the -single option is missing, all agent packages available on the CD for the languages specified through the -P parameter are imported. If the -single option is specified, the specified language package is installed.
- If no language is specified (-P parameter is missing), then for all specified packages only the NLS version (= enu,deu,fra,jpn) is imported.
- If the -single option is specified, but the product and -P parameters are missing, no package is imported.
