The intellisigcmd genuuid command lets you generate unique UUIDs which you can use when creating custom Intellisigs.
intellisigcmd genuuid [num=<count>]
Specifies the number of UUIDs to be generated. If you do not specify this parameter, a single UUID is generated. Otherwise, <count> UUIDs are generated.
Valid Values: 1 to 1000
