intellisigcmd is a command line tool for Intellisigs. This tool has the following format:
intellisigcmd <cmd> param1=value1 param2=value2 ... [<DB_Credentials>]
Specifies the import, export, or genuuid command.
Specifies the database credentials of the MDB. By default, the credentials are retrieved from the comstore.
Use the following sample format to specify the DB credentials:
dbvendor=mssql dbhost=myhost dbname=mdb dbuser=ca_itrm dbpassword=mypwd dbinstance=inst
dbvendor=oracle dbhost=myhost dbname=orcl dbuser=ca_itrm dbpassword=mypwd dbinstance=1521
