You can use the verbose interface for creating and executing CLI commands in a dialog manner. The interface is invoked by specifying the keyword “verbose”. The CLI establishes a session to the manager and determines the type of manager, whether a Client Automation Domain Manager or a Client Automation Enterprise Manager. According to this type the CLI offers the user a list of commands that are valid for this type of manager. For a domain manager running SD the offering looks like:
Valid Commands are: ======================== activate........aregsw cancel..........comconf compgroup.......configure dereg...........deregproc install.........jobContainer managedcomputer recover regproc.........regsw renewjob........setdbcredentials stagingserver...swLibrary targetComputer..templateGroup uninstall quit ======================== Please, enter one of the commands above.............:
You can select one of the commands and the CLI guides you through the valid parameters and their settings. Only those parameters are presented that are needed due to the already entered information. When all the needed information is acquired, the CLI executes the command. The output of the command as well as status information is written on stdout.
When the “loop” option is not coded, the CLI terminates after the specified command has been processed. If it is coded, it returns to the command selection list, so that the user can specify and run the next command. Entering the “quit” command terminates such a session. This quit command is valid in the verbose mode only.
All valid CLI commands are available at the verbose interface.
