Previous Topic: Script File: Inventory SectionNext Topic: The NRI Primer
Script File: Software Section
Control of software inventory scanning is done in the Software section of the script file.
Example: Software Section
[Software]
Method=0/1/2
ScanRestrictedUser=0/1
The following table includes the parameters available in the Software section:
Parameter
Description
Method
Specifies which software scanning method to use. The value can be one of the following:
0 = No software scan is performed.
1 = Runs the heuristic scanner which scans the MSI and Add/Remove database.
2 = Runs the Signature Scanner which uses the CA provided signature database to recognize software.
ScanRestrictedUser
Indicates if software inventory scanning should be performed for restricted users.
0 = No. Restricted users are not scanned.
1 = Yes (default)
