Previous Topic: Script FileNext Topic: Script File: Software Section
Script File: Inventory Section
To specify which inventory detection modules to execute, an Inventory section must be added to the script file. If the section is omitted, the agent executes the basic inventory scanner by default.
Example: Inventory Section
[Inventory]
Method=0/1/2
ScanRestrictedUser=0/1
AdditionalModules=1
Module1Binary=vistainv.exe
Module1Commandline=-o inv.out
Module1Outputfile=inv.out
Module1Cleanup=inv.out,tmp.bak
TemplateModules=1
Template1=user_information.tpl
The following table includes the parameters available in the Inventory section:
Parameter
Description
Method
Specifies one of the default inventory modules. The value can be one of the following:
0 = None of the default modules are executed.
1 = Runs the basic inventory module. Creates about 4KB of information.
2 = Runs the full general inventory module. Creates about 30KB of information.
ScanRestrictedUser
Indicates if hardware inventory scanning should be performed for restricted users.
0 = No. Restricted users are not scanned.
1 = Yes (default)
AdditionalModules
Specifies the number of additional modules to execute. The agent will iterate from 1 to the number of modules specified and read the module information from the ModuleXBinary, ModuleXCommandLine, ModuleXOutputfile, and ModuleXCleanup items.
ModuleXBinary
Specifies the file name for inventory module.
ModuleXCommandline
Specifies the command line to be used to execute the inventory module.
ModuleXOutputfile
Specifies the name of the file in which the inventory module stores the information.
ModuleXCleanup
Specifies a comma-separated list of files that the agent should delete after module execution. Files can be specified with a path.
TemplateModules
Specifies the number of inventory template modules to prompt the user for.
Note: In order to run template inventory through NRI Elective Inventory, you must add the following files to the download section of the NRI Primer script file:
amtplw32.exe, amtext.enu and amm2iw32.exe.
TemplateX
Specifies the file name of template file. The template file is in MIF format, and can be created either by the DSM Explorer or by manually launching the gui_am_tpledit.exe from the Client Automation installation.
