Symptom:
When I run the CA MDM Asset Integration Engine Task the engine task shows the status as error and the asset information is not collected.
Solution:
This may happen if the time difference more than five minutes between the MDM Server and the server on which the engine is running. Ensure that the time difference between the two computers is less than five minutes.
