Previous Topic: Customize MDM_Config_Settings FilesNext Topic: Known Issues and Troubleshooting
Configuring Log File for Client Automation Integration for MDM
The Client Automation Integration for MDM uses Apache log4net for logging capability. You can configure MDMDataIn_Log4net.config file for common log file generation settings such as log levels, maximum number of log files backup, maximum file size.
The following is an example MDMDataIn_Log4net.config file:
<?xml version="1.0" encoding="utf-8" ?>
<log4net>
<root>
OFF - nothing gets logged (cannot be called)
         	FATAL
         	ERROR
        	 WARN
         	INFO
         	DEBUG
         	ALL - everything gets logged (cannot be called)
      <level value="Error" />
      <appender-ref ref="LogFileAppender" />
</root>
<appender name="LogFileAppender" type="log4net.Appender.RollingFileAppender" >
      	<file value="../logs/TRC_MDM_MDMDataIn.log"/>
      	<appendToFile value="true" />
      	<rollingStyle value="Size" />
      	<maxSizeRollBackups value="10" />
      	<maximumFileSize value="5MB" />
      	<staticLogFileName value="true" />
      	<layout type="log4net.Layout.PatternLayout">
        	 <conversionPattern value="%date [%thread] %level %logger - %message%newline%exception" />
</layout>
</appender>
</log4net>
