Previous Topic: Restrictions and LimitationsNext Topic: How Client Automation Integration for MDM Works
How to Integrate CA Mobile Device Management with Client Automation
CA Client Automation Integration for CA Mobile Device Management Asset Information
CA Client Automation seamlessly integrates CA Mobile Device Management (CA MDM) and extracts information about the mobile devices stored in its database. The integration with MDM empowers IT administrators to holistically view and collect inventory of any end points and applications used to access enterprise systems and services. The integration supports Android, BlackBerry, iOS, Windows Phone and the conventional Win 32 (Laptops/Desktops/Servers) devices.
The Client Automation integration for MDM also allows the other products that the Client Automation integrates, to access the MDM Data. For example, CA Client Automation integrates the products CA Service Desk Manager, CA IT Asset Management and by default these products accesses the MDM Data.
MDM Server do not support software as a service (SAAS) enabled authentication due to security restriction. The solution can be used only on premise where MDM Server and Client Automation both are in the same network.
