The status of the task is shown in the engine's task list. It can have the following values:
The engine has not yet run the task.
The task is currently running.
The task has been run and an “OK” status was returned.
The task has been run and an “ERROR” status was returned.
The task list also shows the time, when (if ever) the task was last executed.
While an MDM task is running, the engine console shows the summary of the respective task. Following is an example of MDM task summary:
11/25/2014 2:45:12 AM #=========================================================# 11/25/2014 2:45:12 AM Total MDM Assets Processed Failure : 0 11/25/2014 2:45:12 AM Total MDM Assets Processed Successfully: 15 11/25/2014 2:45:12 AM Total MDM Assets Processed: 15 11/25/2014 2:45:12 AM Total MDM Assets Found: 15 11/25/2014 2:45:12 AM Time taken in the process completion for XIU file generation (in Seconds): 14 11/25/2014 2:45:12 AM Exits processing of MDM Assets, End Time: 11/25/2014 2:45:12 AM 11/25/2014 2:45:12 AM Start processing of MDM Assets, Start Time: 11/25/2014 2:44:57 AM 11/25/2014 2:45:12 AM #===================== Summary Report ====================# 11/25/2014 2:45:12 AM MDM Integration Task Executed Successfully 11/25/2014 2:44:57 AM Performing Job:MDM-Integration-Engine-Task1
