Customizing Asset Management › How to Integrate CA Mobile Device Management with Client Automation › Restrictions and Limitations › Link CA MDM Asset Integration Task to Engine
Once the CA MDM Asset Integration task is created, it must then be linked to an engine or an engine instance in order to be run.
There are several ways of linking the task to an engine. Do one of the following:
- Drag and drop the CA MDM Asset Integration task onto the appropriate engine in the tree view of the DSM Explorer.
- Navigate to the engine in the tree view and click Link Existing Task in the information pane. Then select the CA MDM Asset Integration task in the dialog that appears.
- Navigate to the engine in the tree view and click Add New Task. The Create New Task wizard appears, allowing the creation, configuration, and linking of the task all to be accomplished in one step.
Once linked, the engine performs the task, the next time it comes up in its task list, and the scheduling configuration allows it to run.
