Previous Topic: Organize Software Definitions by CategoriesNext Topic: Enable or Disable Scan for a Definition
Add Product Components
You can organize the product by adding the following related components:
The components created under a parent definition are automatically added to that definition. If you want to add these components to other definitions as well, you can add the product components accordingly.
To add the product components
  1. Right-click a product, release, or suite and select Organize Product.
    The Organize Product dialog appears.
  2. Filter the related components you want to add to the software definition, add them to the Selected Definitions, and click OK.
    The selected components are organized under the definition.
