By default, all the software definitions are enabled for signature scanning. You can disable scan for a definition if you do not want the signature scanner to scan that release or patch.
To enable or disable scan for a definition
Method 1:
The details about the selected definition appear.
Indicates that the scanning is enabled for the definition.
Indicates that the scanning is disabled for the definition.
A confirmation message appears.
This enables or disables the scan for all the linked definitions. For example, for a product, clicking Yes disables or enables the scan for the linked releases, suites, and patches.
This enables or disables the scan only for the selected definition.
Method 2:
The software discovered in the selected computer appears.
The selected software immediately disappears from the list of discovered software, and the Enable for Discovery column under the All Definitions folder is set to No.
Note: Using Method 2, you can only disable the scan for a definition. To enable the scan, follow the steps in Method 1.
After a successful signature scan, go to Domain, Computers and Users, All Computers, Computer, Software, the discovered section and verify the custom software signature definition in the discovered software list.
Custom software signature is now complete.
