Previous Topic: Create a PatchNext Topic: Add Product Components
Organize Software Definitions by Categories
You can categorize and organize your software definitions for easy retrieval per the definition types, manufacturer, and category.
  1. Navigate to Software, Definitions, Categories under the domain manager.
    The existing categories are displayed in the right pane.
  2. Click New Category in the Tasks Section.
    The New Software Category dialog appears.
    Note: You can also use the existing categories.
  3. Specify the category name and other details in this dialog and click OK.
    A new category is added.
  4. Right-click the category and select Organize Category.
    The Organize Category dialog appears.
  5. Filter the software definitions by specifying conditions, add them to the Selected Definitions, and click OK.
    The selected definitions are added to the category.
