If you are using Open Workbench with CA Clarity PPM, you can create a new Open Workbench .rmp project file and then save it to CA Clarity PPM if:
When you save the project to CA Clarity PPM, the following occurs automatically:
Note: If you save an Open Workbench file as a CA Clarity PPM project record, then its External ID is the default ID you entered in the Project field in CA Clarity PPM. If it matches an existing project record's External ID, you cannot save the project to CA Clarity PPM. You can save a project over an existing project if you save the project using an existing CA Clarity PPM project ID. If you save over an existing project, the new project information replaces the existing project information.
To save a new project to CA Clarity PPM
The Save As dialog box appears with a list of projects that you have rights to view or edit.
Displays the CA Clarity PPM server that Open Workbench is currently connected to when opening projects from CA Clarity PPM.
Click to see a list of available project names.
(Default view) Click to see a detailed list of available projects.
Click to open Open Workbench .rmp project files or XML files from your computer or network.
Click to save the project to CA Clarity PPM and to display available projects from CA Clarity PPM.
Displays the current folder when saving Open Workbench .rmp project files or XML files to your computer or network.
You can filter the list by using the wildcard (*).
If you enter a*, only projects starting with the letter a or A are displayed.
(For the CA Clarity PPM project detail view only)
You can sort the list by clicking column headings. Columns displayed include:
Displays the project ID when saving the project to CA Clarity PPM. If the project ID is unique in CA Clarity PPM, a new project is saved to CA Clarity PPM. If the project ID exists in CA Clarity PPM, a confirmation message appears letting you know the ID already exists. Click Yes to replace the existing project with the new project information.
Displays the file name when saving Open Workbench .rmp project files or XML files to your computer or network. Enter the Open Workbench project name or enter the XML file name (.XML).
Defines the type of file you want to save the project.
Values:
Specifies whether or not to hold the lock or unlock the project when saving it to your computer or network.
Note: This check box is displayed when you choose Open Workbench or XML from the Save Type As drop-down.
The project is saved to CA Clarity PPM.
| Copyright © 2010 CA. All rights reserved. | Email CA Technologies about this topic |
