If you are using Open Workbench with CA Clarity PPM, you can save a copy of an existing CA Clarity PPM project as a new project in CA Clarity PPM using Open Workbench. When you save a copy as a new project, all project information is copied to the new project. Both projects exist independently of each other. No file sharing occurs.
To save a copy of a project as a new project in CA Clarity PPM
The project opens in Open Workbench.
The Save As dialog box appears.
A message appears asking if you want to unlock the original copy in CA Clarity PPM and remove the working copy from your computer or network.
A copy of the project is saved. The project is locked and open in Open Workbench.
Note: See the Project Management User Guide for more information.
| Copyright © 2010 CA. All rights reserved. | Email CA Technologies about this topic |
