Using CA Clarity PPM with Open Workbench › How to Save Projects back to CA Clarity PPM › Save Existing Projects back to CA Clarity PPM
If you are using Open Workbench with CA Clarity PPM, you can save an existing project back to CA Clarity PPM. To do this, you must have edit rights and you must have a lock on the project.
When you save an existing project back to CA Clarity PPM:
- And the project is locked, the project is saved but remains open in the view and locked.
- And the project is unlocked, a message appears letting you know you cannot save a read-only project.
- Once you save an existing project back to CA Clarity PPM, you can save the project as a new project.
To save an existing project back to CA Clarity PPM
- Select File, Save.
The project is saved to CA Clarity PPM but remains open and locked.
- Click Save As.
The Save As dialog box appears.
More information:
Save Copies of Projects as New Projects in CA Clarity PPM
