How to Save Projects back to CA Clarity PPM
If you are using Open Workbench with CA Clarity PPM, you can save projects to CA Clarity PPM using CA Clarity PPM Schedule Connect. You can:
When you save a project updated in Open Workbench back to CA Clarity PPM:
Important! If you save a CA Clarity PPM project as an Open Workbench .rmp project file while the Retain Locks check box is selected and continue to edit it, and then save the project file again, a message appears letting you know that you are saving a non-working copy. If you continue, you will be unable to save the project back to CA Clarity PPM as the original copy. You can only save a copy of the project as a new project with its own unique project ID.
More information:
Save Existing Projects back to CA Clarity PPM
Save New Projects to CA Clarity PPM
Save Copies of Projects as New Projects in CA Clarity PPM
