If you are using Open Workbench with CA Clarity PPM, when you open a project from CA Clarity PPM into Open Workbench, the Download Manager window may appear. You can close this window without taking any further action or you can prevent the Download Manager window from opening when Netscape Navigator encounters an encrypted page.
Best Practices: Set the following browser options when you are connecting Open Workbench to CA Clarity PPM using CA Clarity PPM Schedule Connect.
Note: See Netscape Navigator Web browser Help for more information on setting Netscape Navigator Web browser options.
To set Netscape Navigator web browser options
The Preferences dialog box opens.
The Downloads dialog box opens.
The Help Applications dialog box opens.
Enter CA Clarity PPM Schedule Connect.
Enter nikusl.
Select the check box.
| Copyright © 2010 CA. All rights reserved. | Email CA Technologies about this topic |
