Install the connector in the server where CA Process Automation is installed to connect to the vSphere client. The VMware vSphere Connector provides CA Process Automation access to a vCenter server using the vSphere API to perform functions such as creating and starting virtual machines.
Note: You can install the latest vSphere Connector(Version 4.0) that is shipped with the service cartridge.
Note: To confirm that the Orchestrator you are shutting down is the Domain Orchestrator, examine the setting for oasis.server.isPrimary in the OasisConfig.properties file. The OasisConfig.properties file is found in <itpam_root_directory>\server\c2o\.config, where <itpam_root_directory> is the directory where CA IT PAM was installed. Verify that oasis.server.isPrimary=true.
Go to the cartridge installation folder as noted in the worksheet, go to the vSphere Connector installer file.
PAM_Connector_Installer_vSphere_4_0-w64.exe
Note: Select the file that is based on the server operating system type. For example, a server operating on a 64-bit operating system, you select the 64-bit installer file.
The installer Introduction page opens.
The License Agreement page opens.
Note: This page displays the default installation directory for CA IT PAM.
A web page opens.
The Install CA IT PAM Connectors page opens. When the installation completes, the Completing the CA IT PAM Connector Setup wizard page opens.
