After you install the agent, configure the touchpoint for the agent in CA Process Automation. Touchpoints are used to identify the orchestrator or agent within an environment. A touchpoint is the host on which you install the agent. The agent is used to execute the powershell in a host. You can add touchpoints one at a time or you can add them in bulk. Use the following procedure to add a touchpoint to a selected environment and select the agent to associate it with. This identifies the location of the CA Process Automation agent to the orchestrator.
All the configured environments are enlisted.
A web form opens.
Note: You select the agent that is installed on the VMware View server.
A new touchpoint is added in All Touchpoints in the Default Environment.
The touchpoint that you added appears in All Touchpoints in its environment.
